Part numbers for top mounts and brake line retention clips
LostInSpace
I need to replace my top mounts and brake line retention clips on my 182 CUP, but RPD can't confirm the part numbers, so I need your help....
Top Mounts:
Standard top mounts required, happy to use either Renault genuine or Febi. Car has standard Cup struts. I want to replace everything above the top spring perch. I found the thread discussing the updated mount design and believe there is a kit containing everything I need?
Brake Line Retention Clips - the 'U' shaped clips:
  • Front: These are located on the wheel side of the front wheel arches and connect the hard brake line to the soft flexible line running to the calliper.
  • Rear: As shown by the 4x red arrows in the pic below.
    • Are they the same part as the front clips?
Can someone confirm the part numbers please.
