DCI100 ignition Problem?
Car  clio dci 100
Ayup lads, Got a problem on my Clio dci 100bhp 2004 Model, Drove to take shop came back 5mins later and turn ignition on and wouldnt tick over dashboard starting flickering with lights and made a noise when turning the key sounded like when 2 wires touch and spark kind of noise only way to explain it. any help be great cheers.
Start with checking the positive and negative terminals on the battery. Then follow the harness around the main fuse box and check for any split insulation, also check all fuses. If you say there is a sparking noise, maybe part of the harness insulation has come away or something.
Could be as simple as the battery has packed in. Check that first of all with a multi meter
