renault trafic
jed
  derby
hi everyone
I have Renault Trafic 2.0 diesel 58 RG parked for 1 month and battery flat. I removed the batteries and putting new battery but van want start if anyone knows helps me, please
jed
  derby
Hi It's new battery turn over but want start
And engine red flash also have follow code show
botfch
  Clio 182
Looks like a fueling problem, under the bonnet on the left hand side there should be a fuel filter.
Does it have a rubber hand prime pump?
jed
  derby
I openid engine cover all pipes fin no leek
And hand pumping but still turn over but want start
Speedo Gonzales
That's immobiliser issue. Disconnect the battery, then reconnect it with the key in the barrel
Then lock and unlock the doors with the key button. Hopefully the van will 'see' the key then
Speedo Gonzales
@Martin_172 ?
Nah but if you hold the door lock button in on the key, turn the key to ignition just before the crank, hold it there for 30 seconds and then flick it back and let go. That did work on a 1.2 16v my brother had where the key was buggered
Or hold the door lock button for 30 seconds with the key in the ignition on position
f**k knows, get the ouija board out. It's a Renault
Ol’ Tarby
  Clio 220 Trophy
On mine I just put the key in switched ignition on and pressed the lock button once. It then fired up
  • Like
Reactions: jed
jed
  derby
Hi everyone I do ALL above but still not starts, I bring mechanics diagnostic and find voltage circuit c prominently off not give the power to start.
he says well come back to u on Sunday with the special machine to find a wire,s where is cut I
well forward if fix on Sunday.
jed
  derby
God news I removed plug injector connectors
Number 4 and spray easy starters
Now my trafic work and after 1 and half hours
Start without easy start
But when I put back injector plugin it's straight away cutting aut. but if plugs disconnect
It's start and drive but limp mod
I don't know really exactly what is wrong with van
My English not good sorry
If any one know the problem let me thanks
