ripp
182 FFAT
Hi guys
I want to share my experience with these pads, maybe it will help someone in taking the right decision regarding pad choice
First of all, they were fitted in september 2016 along with new discs, ATE plastilube used on pad contact points with the caliper and piston to avoid any seizing, the calipers were also refurbished with new guide pins and so on and the brakes were bleeded and Motul RBF660 DOT 5.1 fluid used.
The car is a Clio 182, and since then it did 18 000 km.
I live in a European country with temperate climate (not on the seaside so no extreme moisture conditions involved).
I went to two different trackdays, one late september 2016 and did a 20 minute session with couple of cooldown laps and the next one in octomber 2018 - also one 20 minute session with a couple of cooldown laps. Both sessions on the same track on nice sunny days with 20-25 degrees outside, on a 4km medium speed track.
The rest of the time the car was used as a street car with normal driving, almost daily (maximum 5 days between drives-these were exceptions) both around town or short to medium distances (50-200km per trip)
I was very satisfied with how the pads performed so far, good bite from cold and without any fading in the track sessions that I detailed above.
Unfortunatelly a couple of days ago when I left the parking lot I heard a clunking noise from the front axle, came to an imediate stop and found that one of the pads had been stripped of the braking material - part of it remained attached to the front disc.(it's the outer front left pad)
You can see in the pics all of the front pads removed and measured, they are still usable - thickness wise, so they aren't worn out to their limit yet, at least according to the car's owner's manual (also PDF attached with those specs)
Have to say that this event got me worried, as I intend to buy EBC pads in the future, but am a bit concerned about this problem.
I sent an email to EBC and their answer was:
"From the pictures you have set us it looks like were the disc has rusted to the pad, this isn’t a common thing to happen to this extreme.
It mainly happens on cars that sit for a while."
I also talked to the guy that sells them here and his answer was smth like "of course this happened, you went on the track, this combined with the fact that they are almost 3 years old and rusty, no wonder the material came off"
I want to know what you guys think, because in my book, after nearly 3 years and without excessive wear and abuse, this should NEVER EVER happen to a pad. I had DS2500 before and they stood up perfectly (never tracked them though but gave them some abuse on mountain roads couple of times) and when they came off the car didn't looked like taken from the Titanic wreck..
Enjoy the pics!
Enjoy the pics!
