Turbo cams
Hxrry
so-wax.com
ClioSport Trader
Hi guys,
I'm in the process of sourcing parts for a turbo engine build with forged pistons/rods etc
I'm unsure whether there would be a benefit to running cams (such as catcams)
I've seen it mentioned once that people use the 197 inlet and 182 exhaust cam or maybe vice versa... Is this a good option?
  Defender 110
I’m sure the standard F4R cams work better with the turbo, rather than the F4RT standard cams iirc...
isn’t it something with the n/a cams lift duration works well..? So basically a mild upgrade by keeping the n/a cams.
If I’m remembering correctly, it’s the same principles as the Vaux guys putting the n/a versions inlet cam into the turbo engines.
Hxrry
so-wax.com
ClioSport Trader
I'm not entirely sure hence why I asked but that's good to know! I did somewhere about using one of the two 197 cams, I'm sure it was inlet. I will try to find that again.
Standard cams for boost
@bloke got suggestions on this one?
Standard cams are cheaper so I'm happy lol.
Hxrry
so-wax.com
ClioSport Trader
The Megane guys run 182 cams in theirs, so they are well suited to boost.
That's fair enough then. Luckily the 182 cams aren't expensive.
