Electrical gremlins
DomP182
Car  ph1 172, Arctic182
I've had this problem for a while now so sorry if I've asked the same question before.
When I open either door the interior light doesn't come on (does when unlocking though) in addition and I believe linked is that the doors autolock even after I've opened them. This can be when a door is left open or if I get in and shut the door, the alarm will go off if I'm inside unless I put the key in the ignition and turn it on one click.
Boot switch works, and I've tried replacement door switches
Dash top off it is then, I tried testing the wiring with my multimeter but I'm not exactly sure what I'm doing other than doing a continuity test
I'm not sure what to test with a multimeter either.
If the doors are autolocking after a while, the car obviously thinks the doors haven't been opened so it has to point to that area.
Also why the interior light doesnt come on I presume
