197 Throttlebody on 172? and pedal replacement
Car  clio 172 ph2
So I think the throttle body and/or pedal on my 2001 phase 2 172 is on its way out. Throttle response seems a bit laggy and I have had serveral occations where the electric fault light is on and the car just idles when pushing the throttle.
I plan on replacing both the pedal and the body just to be sure and I was wondering if a 197 body would fit the 172. As these are still being sold new. Or i might even pick up a 2nd hand one as these would be serveral years newer.
As for the pedal, is there a place where I could buy these new of even used but checked? There are several pedals on ebay but I dont really thrust them as they also could be worn.
Thanks
Dentillozie
Unsure on if a 197 throttle body would fit but I do have a 1*2 throttle body for sale if you need one. Fully working when removed.
as for the pedal,
would anyone know if the pedal out of a 1.2, 1.4,... (part 8200089851) would work?
They can still be bought new and they seems almost identical to the pedal in the 172/182 (part 8200089857), Just rubber pedal instead of alu. looks easy enough to swap over.
