Sunflower Ph1 172
I know this must get asked a lot (I've done a fair amount of research!), but just a query on driveshafts.
Am aware that there are several different driveshafts for Ph1 172, 172 Cup, 172/182 Non-Cup and then 182 Cup.
I am looking for a new right hand/drivers side/offside 182 "Cup" spec driveshaft.
OE part number is 8200372166 or 8201187820.
Both KTR and RPD list the 8201187820 (essentially exchange unit), but both say Renault have no stock, and can't give a date on when there will be any stock.
About 3 or 4 weeks ago, I went onto ECP website and saw a GKN item available, which I bought, thinking the specs were correct with what I expected a 182 Cup driveshaft to be.
Today, I looked at the specs on their website again, and see that they list this as a replacement for OE part number 8200352042 which is a Non-Cup driveshaft (clearly missed this when I purchased).
So my question; do I need to return this driveshaft because it will not be compatible?
I've not even attempted to fit the GKN item yet so no idea if it even matches up or whatever. But if I know for definite it won't, would rather just return it for a refund whilst it is new and boxed.
From what I have read, the main difference between the "Cup" & "Non-Cup" O/S driveshaft is the ABS rings, with Cup ones being thicker? This new driveshaft appears to have thinner rings?
If this is the case, would I get away with just replacing the ABS ring for something like this ?? Or is this not possible?
I'd like to go genuine if possible, but seems difficult to get hold of one.
GKN seemed like the next best option in terms of quality. Am aware there are alternatives from J&R and Shaftec but not sure how good these are? The fact you can get a new J&R shaft for circa £50 would not give me much confidence in it lasting!
Pictures of the new driveshaft for reference, below.
Thanks for any help.
Ash
Ash
