Paul.M
Hi all,
Thought I would start a thread on my 30th Birthday present to myself.
I have been looking at these for about 5 years on and off but never gone through with buying one, lockdown must have got to me as I took a massive gamble and bought this sight unseen from the opposite side of the country and had it delivered... Very out of character for me!
Luckily I've had it on a ramp and it all seems to check out solid enough, I have replaced the front left wheel bearing, a headlight ballast and done the usual tidy up bits, new bulbs and plates etc.
It's a 2002 with 122k on the clock.
Imported in 2006.
Came with a massive stack of paperwork including the Japanese history, it was a grade 4 import.
Spec is as follows:
Oem shocks with spoon springs.
Pbs pads all round, j hook front discs, hel braided lines and mtf600 fluid.
Custom cat back.
Hard race rear camber arms, front eibach Camber bolts.
Super pro front caster bushes.
Full geo set up (more on this later).
Tegiwa short shifter.
I took it up the lakes for a couple of days this weekend and it performed faultlessly. It gets loads of attention too, I keep getting people asking about it at lights or when I park up etc which is a new experience.
Immediate plans are a decent set of tyres all round, it has budgets up front at present as the previous owner had it on a set of different wheels, I'm also going to read up on setups and get it in with grinspeed or tenspeed as the current geo seems a little extreme to me, it's running 3 degrees negative camber up front, that may be normal but to me it seems a bit overkill, get a couple of dents removed and get out on track, a couple of friends have invited me out to the ring next month but I think that might be a bit soon for me to get it sorted due to other priorities.
I would also like to get the exhaust tip replaced for a smaller one at some point as it's a little too big for my taste but this won't be a top priority.
Thanks
Paul
Imported in 2006.
Spec is as follows:
Custom cat back.
Thanks
Paul
