Underside blanks
04-182
  AB Clio 182
Hi. Can anyone tell me if there is supposed to be a blank in the middle hole. Seems odd that there is one either side. Both sides of mine are the same.
Also on the frame rail.
If yes where do I get them from.
Thanks in advance.
YorkshireKyle
Cheers. Is it just sticky tape? Might see is I can print some blanks. Need to replace the under seal that’s worn away aswell.
It's like really thick sellotape mate, if you do design a blank make sure you make it with a rubber edge like the others to try and stop water getting in :)
04-182
  AB Clio 182
Will do. Will see if I can find some rubber inserts on line first but if not I’ll have a play 3D printing one in rubber.
