I work in a garage and honestly the timing belt snapping issue is very, very rare. Most people’s cars we see have been neglected and often on belts way over the service time
What does tend to happen quite often is people’s aux belts snap and take out the timing belt then that usually gets turned into “the timing belt went”
Generally if a timing belt is done the aux belt will get done and th
If there has been a timing belt issue it’s usually more likely to be from a failed tensioner or idler or poor fitting of a recently done belt.
That’s why I’m quite keen for people to have aux belts sorted if any cracking is showing during service inspections (although people often want to leave something til it breaks)
I’m certainly not saying don’t get it done and in fact do get it done as it’ll often highlight other issue but I can say I did a clio a few months ago that was 4 years overdue, belt looked perfect. The aux belt and crank pulley looked tired and could have let go at any 6krpm moment.
I’m currently going through timing belt jobs on a classic collection for a friend/customer (private) and all the belts look perfect and all 5-8 years old.
I'd rather run a car with a belt over on mileage than one thats older on date.
Every 5 years regardless of mileage is the recommended interval
And a headgasket every 15 minutes 😂 😂Some are different to others.
It's 100k miles on the 1.0 turbo Ford engines IIRC?
On the belt... ProbablyRight so I done the aux belt not long ago does that mean I have another 5 years? 😋
No ac or pasOn the belt... Probably
If you still have the spring tensioner then definitely not 😂
Best way mateNo ac or pas![]()
Best way mate
I run a 4pk845 on my clio with no PAS or AC. Saves so much room! Although I must have caught a stone or something with no undertray because it has a slight nick in it now![]()
Just make a massive splitter 😂Hm it is quite open to the road aint it. I want to stick the undertray back on tbf, so I dont have to look at all the leaks when I jack the car up!
there's plenty out there popping up with snapped belts that I bet were on their original belt of 15yrs+
Most of the ones I've seen have been aux belt/tensioner failure that's taken out the cam belt.
if its done 3k miles on its current belt there's not a chance in hell id be changing it! but id do an aux kit on it. HOWEVER if i was buying one and the owner told me it had only done 3k miles on its current belt, id be doing it, Worth keeping in mind if your selling...
Seems like you caught it in time.
Should have just gone the whole hog, taken the engine out, done the belts, done the clutch, bang the engine back in with the addition of the spooly boy.
Birds C4 was on original belt (08), their interval is 100k or every 10 years
Citroen should have adjusted their service intervals for my Mrs, about half would seem right however the car is generally well serviced and on 80k. However stood for around a year before she had it, suggests that perhaps time is just as important as miles (maybe more?). either way it had done 3 years overtime without pay so spat its croissant out and ruined my Saturday.
Belt looks no better than the Clio's (design/quality wise) so they must have reduced interval because of all the little chavs ragging the s**t out of them, aux belt bulk factor and the desire to ream more customers at service time. Rest of the belt looked fine, no cracking etc.
Jumped 2 teeth but didn't hurt anything (so dodged the scrap man for another day). I would be fine with 5-8 years on the 182 timing belt as long as the aux was done as per book (which they reduced from 5 years to 3 due to failures), however 8-10 years would be giving me the willies.
Timing belt isn't much harder than the aux, should have rolled your sleeves up lad![]()
Based on my ownership of well over a hundred various Renault's over the last 24 years, the general approach I take is mileage driven. I have never had a belt fail and in fact i've never even taken one off that looks close to failure.
Always change the belts on purchase unless there is definitive proof of change with date/mileage.
If a belt has done little mileage i'll extend the time interval by up to 50%, so my Clio V6 was done in 2015, has done under 10k miles and I plan to change the belt for the 2022 show season. I ran my 21 Turbo like this for 20 years before it was decomissioned for resto in 2018.
If a belt is around half mileage i'll extend it 12 months or so. Usually applies to her runaround, or my 2nd car.
If a belt is close to mileage then it gets done on time, which usually applied to my daily.
Finally if a belt hits mileage before time i'll change it on mileage. Think thats only happened once though.
Aux belts are generally a shorter interval and I tend to do these on sight, as they are easy to inspect with a torch, even on the Vee.
