Pistonheads Clio 182 article
Crazylegs
  Clio 182
Very interesting, not sure I'm confident enough of a driver to bump the pressures up that high on the rear but I might knock them up a little bit more and see how the car feels.
ajracer
Well I gave it a go this afternoon.
Bearing in mind I have B14 shocks and the car sits fairly low.
Pumped them up to 37psi and went out on my usual test route and against my instincts the car felt much more planted in and out of corners. Did feel a bit hard and crashy on the back end though. Maybe peg it back a bit for road use.
ajracer
I think the whole point in putting more pressure in the rear tyres is so that there is less outright grip on that axle, thus making the rear more mobile and and adjustable.
I’d be very surprised if the car felt more planted as I suspect the reality will be the opposite!
My bad. What i meant was the front end felt more planted under braking and out of the corner. Maybe it’s because the rear tyres aren’t affecting the balance by having less grip. Really wouldn’t be too confident pushing on in wet conditions.
Ah, yeah, that is more how I would expect it to be. Far more front driven than normal, if that is even possible!
R-Sport.
  Mint 1*2's for sale-
If the normal pressure is about 32 for PS3s whats a step upin pressure on the rears - 36?
Crazylegs
  Clio 182
I run 34 front and 32 rear in mine but I may bump the rears up a tad now next time the tyres need inflating.
