182 Trophy Brembo Conversion - Do I need them machining?
Car  Bus Winker
Hi All,
I'm after some advice on this topic related to 280/300mm discs and the Brembo machining.
From what I understand if I use the below parts on my Trophy I won't need to machine the calipers, is that correct?
Sorry, I know this has been covered before but I'm seeing conflicting information so just wanted to double check before I get the caliper refurbed.
I'm going for the 300mm setup because from what I have read this doesn't require any machining.
Bracket - Pure Motorsport - Clio 2 300mm Brake Bracket Kit http://www.pure-motorsport.co.uk/brembo-300mm-brake-bracket-kit
Lines - Pure Motorsport - Clio 2 300mm Brake Line Kit http://www.pure-motorsport.co.uk/brembo-300mm-goodridge-brake-hose-kit
Pads - Ferodo DS2500 https://www.godspeedbrakes.co.uk/ferodo/373-clio-sport-172182-front-ferodo-ds2500-pads-.html
Discs - Clio 172/182 300mm G Hook Discs for clio 197 Brembo caliper Conversion https://www.godspeedbrakes.co.uk/br...300mm-g-hook-discs-for-brembo-conversion.html
You will also need 10mm spacers as you are using Trophy Turini wheels
Cheers, will these 10mm do the trick?
https://www.kamracing.co.uk/car-tun...re-motorsport-wheel-spacers-renaultsport.html
