Changing a clutch cable Clio 182
  Land Rover
Soooo.....after booking this job in with my local garage and being quoted £100 l decided to try and fit it myself.
It took me 2 hours but next time l reckon l could do it in one.
Procedure?
Raise the front of the car on ramps or axle stands.
Remove battery and air box/induction kit.
Disconnect clutch cable at gearbox.
Remove cable from clutch pedal.
Take out two 10mm bolts and fold back insulation material from footwell where the cable goes through.
Remove a small plastic locking ring from the cable in the footwell (use a pair of pliers to free it)
Take off the engine cover (if fitted) and remove for tree clips/large screw type clip holding the soundproofing to the engine bay bulkhead.
Unbolt the coolant reservoir tank.
Using a small jet flame lighter MELT THE PLASTIC CABLE MOUNTING and then push it through the bulkhead.
Tie some string around the cable end.
Pull the cable out from the engine bay side. Unclip it from the various clips and finally remove it.
Tie the string to the pedal end of the new cable. Pull it through (you’ll need to alternate between the footwell and the engine bay a few times)
Eventually the cable end will be visible through the hole in the bulkhead and you’ll be able to pull it through, l needed to help it with a small screwdriver as it was at an angle and wouldn’t come through by just pulling the string.
Put the cable through the hole in the sound insulation and then fit it to the pedal mechanism.
Make sure the cable outer comes through the hole, you won’t be able to pull it right through to engage the clips but it will locate the first time you operate the clutch.
Refit the plastic locking ring to the cable.
Refit the footwell insulation.
Poke your arm behind the soundproofing on the bulkhead and locate the cable in two clips. Locate the cable in a third clip near the N/S wheelarch. Attach the cable at the clutch end.
Re attach the engine bay soundproofing.
Refit the battery and air box etc
This was not a difficult task and the clutch action was improved (smoother/lighter) although still no VW Polo.
Louis
I Love Ed Sheeran
Thread bump but struggling with removing the clip from where the pedals are. Do I need to snap off the plastic locking part? Dont see how it easily comes off otherwise
Louis
I Love Ed Sheeran
Sorted now. For anyone in the future the little rubber guard prizes off. You can then access the clip underneath which you use long nose pliers on and a screwdriver to push out.
  Land Rover
Read my post above! lt's in capital letters.
Just heat it with a jet flame lighter and it will soften and fall out of the bulkhead, then you can fit the new cable.
Takes a few seconds and it's out.
Louis
I Love Ed Sheeran
I saw that but didnt want to take a naked flame under there at all. Literally prizes off easily once you know you wont break it.
  Land Rover
No issues with the tiny flame under the dash, directed at the cable only to heat the plastic locating clips.
Obviously as with anything care is needed, at the time there was no easy alternative that l could find online.
l am glad you managed to sort it though. Changing the clutch cable on a Clio 182 isn't the easiest job.
Louis
I Love Ed Sheeran
Yeah your guide was really useful thanks for posting it!
For people in the future if you dont fancy using a lighter just open up the clip along its joint then force it forwards. Make sure the string is also strong enough as it's a lot of faffing to get the cable in the right position.
Is this the jobby as I can't get this through the bulkhead. Snapped 2 bits off the top. Which doesn't matter but struggling.
Tried a flame torch and yes scary woth all the stuff under there. Got a cup of water on hand.
Also spent over an hour on just this bit. Total time so far tonight is 3 hours!
1 hour removing battery tray to refit after realising nowhere says the tray, although i had in my mind some reason as easier access to cable routing.
Currently stuck with a cable almost out but not quite. And can't even attempt the new one yet!
I will have so much satisfaction after doing this. But I am getting a little wound up. Plus seeing places where I'd believe bolts or nuts to affix things would be
