Stock are M8 but cant remember the length off the top of my head. They will still accommodate an 8mm drop on the column.What size bolts did you use?
Drop one out and get some 8mm longer, they're super easy to access![]()
Perfect. So I can run an 8mm drop with standard bolts?
Next question. Where did you buy those from? I was looking at just throwing washers in but this looks far more like me!
See images above.Where exatclty does this 8mm need to go?
Yeah stock bolts will cope with 8mm but i did change em at a later date. I had these turned up for another project so already had them on the shelf. Pretty sure ive seen a fella on Faceache selling steering column spacers.
Quick search threw these up.
That's tonight's job sorted then, didnt realise how simple would be, thanks all.
I could also do with doing this. After fitting my 330mm wheel, it seems mega high now!
top man! I don’t know if I’m honest, just researching now. It looks like @frayz used some 8mm stand-offs which work with the standard factory hardware? I would think 10mm would be about right, but unsure as what, if any ramifications would be in terms of changing the bolts over from factory to non standard. Probably should get off my arse and take a look!@RustyMojo What is needed M8 hole and 8mm thick? If that's correct I'll knock some up at work today and bring them home with me. I've only just seen this thread and have the same problem with the wheel being slightly high now.
Can do any size you need mate if you don't fancy 8mm thick. I may have some longer M8 bolts kicking around if you know how long you want them?
I'm thinking of knocking up a couple of different thicknesses to have a play withI ordered M8 x 6.3mm thick by the looks of my eBay order history and had no issues with using the standard bolts. I’m sure 8mm thickness would be no issue, but I ended up playing it safe and ordered the 6.3mm (1/4”) ones.
Sure thing, I got started on them this afternoon and then held off till I got a reply. I'll get them sorted tomorrow morning for you.@VenomUK if you knock up some 8mm ones can you do me a set? I’ll give them a go first then decide if I need more. Hopefully that should be just the ticket
Nothing mate, you got me a coffee at C&MLegend cheers mate, let me know what I owe you I can pop around and grab them
I’m not sure yet? But have been doing some research. Much of the information is in this thread. M8 with an 8mm standoff height seems to be the initial setup as that uses the OEM bolts? Venom has made a couple of sets to experiment.I fancy having a go at this. Does it matter how wide the spacers are?
