4 pots on 182
Car  Clio 3 1.2 tce 2010
Hi there what braided brake lines are people using on the clio 182 with 4 pot callipers I have found the ones pictured below but not sure if they are compatible
Many thanks
I run the BRT lines on my car, never had an issue with any of their products
What do you run to the standard callipers on the rear?
What adapter bracket do you use aswell sorry to be a pain
I used these on mine. You’ll need 16” wheels for 300mm disks though I believe. Standard 182 wheels fit with 15mm spacers
Could I not run standard 280mm discs with the standard 16 wheels that’s what my thought was???
You could but the only reason to run 280 is to fit 15s. If you’re sticking with 16s go for the bigger disks.
You can use disks off a early 2000s scenic of some flavour and they are cheap as chips
