Cheapest bluetooth solution for standard head unit?
  Renaultsport Clio 172
Any recommendations? Want to keep oem head unit and want to avoid fm transmitters.
Lots of adaptors on amazon but do they actually work?!
MatthewR
I bought a aux in adaptor years ago for the MK2 from there I bought a Bluetooth to Aux adaptor and then had Bluetooth audio only for music streaming
Jekyll
What you need is a denison kit.
It plugs into the back of the OE headunit in the CD changer port. It has built in bluetooth so you can stream music through it and still use the stalk control as per normal, changing tracks, volume, etc.
I had one in my RB and worked great. Only downfall is the track listing on the screen isn't the same, think it say 1 of 99 or something like that, but it's easily dismissed.
  Ph1 172
I have had no issues
But i wanted to stick with the OEM look and keep the standard head unit.
I bought this
Naively thinking it would just slot straight in but it must be for a later 172. There are 6 points on the connector but the one that you take out for the CD changer has 8 in a different configuration.
That tape option looks like it could be a good alternative, although seems too easy! Nothing is on these ever! Ha!
bowen86
Looking for solutions for my 172 cup.
The above links to the green plug Aux Wire isn't compatible with the 172 Cup Tuner List model. The green plug is the wrong shape and even triming it to fit it didn't work.
Anyone have a good Bluetooth solution for a 172 Cup?
