I am looking to add camber shims to the 182, I was speaking with my mechanic friend and he said that depending on the way the axle sits on the wheel adding camber shims might change the Toe and then you need to get more shims to correct the Toe.
So, my question is simple, does adding camber shims to the back change the Toe as well or does it remain largely the same?
