Wheel bearings on a 172 Cup...talk to me.
ex-Chinese Dave
  172 Cup
I have a slight whine around 25-35mph that is there when I dip the clutch. I'm pretty sure it's a wheel bearing but not sure which. I'll be jacking it up on Saturday to find out.
I did one or two years ago on my XR3i but what are they like to do on a 172?
ex-Chinese Dave
  172 Cup
Haha sorry mate, they're not a simple bolt in job like a lot of modern stuff now.
Hopefully it is just a bearing and not the gearbox.
It's not the box as I've just had a refurbed box put in. When I dip the clutch the whine is constant. It's not bad but these things never get better.
Colin-S
  172 Cup
I thought when a wheel bearing goes - the faster you drive the louder it gets?
ex-Chinese Dave
  172 Cup
When they start to go there’s usually a light humming noise to start with and I think that’s where I’m at. I’ve not noticed it at motorway speeds but there’s a lot of other noise happening at 60-70mph. When driving gently up to 30-35mph it’s noticeable.
I think the noise is coming from the n/s/r so if so maybe it’s time to do the discs on both sides (I was thinking of this last week coincidentally) as I’ve read that the bearing come ready fitted in the disc.
Jamie86
  RS175,595,205gti,172
You can buy the bearings as well though if discs are fine. Most garages would press it in for you for a drink I’d imagine.
Jamie86
Just more to go wrong. And they’re not expensive to replace the whole disc mate
No agreed. New disc is easier option but seem to remember prices have jumped recently? But then not bought any Clio parts for a while.
Advikaz
AUTODOC always makes my head hurt tbf
JamesBryan
This car of mine did about 1500 miles in about 11 years before I bought it last year. Now that it's my daily it seems that 11 years of almost no maintenance has caught up on it.....but I still love it. Aww.
Sat there doing nothing, things seize up and as soon as you use them it starts to show.
Like collectors of supercars, hardly any mileage on them. As soon as they start them up the engine starts leaking as seals/gaskets dry up and they piss oil.
ex-Chinese Dave
  172 Cup
I've just jacked it up and checked the wheels. Tyres are all normal and rocking all the wheels top to bottom and side to side I can feel no loose play at all. When spinning the rears the o/s rotates fairly freely and the n/s less so. They don't spin easily and continuously and there is the usual sound of the brake pads touching the discs a little. Having typed that I wouldn't say there's a lot of resistance to spinning them either. Would you opt to change them?
I could also be that bloody exhaust!!!
Anyway, I off to ruin a good walk on the local course.
Advikaz
Could be a seized/seizing caliper
ex-Chinese Dave
  172 Cup
This was checked at Birchdown today and I also found there's nothing wrong with the wheel bearings. The n/s/r Toyo tyre is slightly out of shape and this is causing the humming sound.
ex-Chinese Dave
  172 Cup
Just updating my posts....
This has not been solved. I've had brand new tyres fitted and the wheels refurbed and balanced correctly. The noise is still present and we think it's a noisy diff. Next time it's in we will use a different spec of gearbox oil to hopefully reduce the noise.
