Gearbox model identification.
Car  Clio
Hi there, new member and first post so sorry if I have put this in the wrong place or not asking the right thing. I'm really hoping someone on here can help me. My mother has a older 2006 clio and the slave cylinder in the clutch decided to start leaking. I have a mechanic who will fix this for me but for the life of me I cannot find the gearbox version stamped anywhere on the box. Have looked by the filler hole, near the earthing bolt and other places I've read online as to where it should be. Only reason I need this is there two version of the slave cylinder with different size feed pipe connections. Don't want to purchase the wrong kit and it doesn't fit. Reg plate is SJ56 VDP and vin number is VF1CR1A0H36524639. Any help would be so appreciated. Thanks.
Its a JH3 box
I'm sure all of the slaves are the same on them. They're used in absolutely everything
The only difference is the pipe outside of the gearbox iirc. Can you get a pic of the pipe coming out of the box?
Its a JH3 box
Hi, yeah as far as I could see its the pipe attachment that's different. One is 12.2mm and the other is 13.3mm. I have tried getting a picture of the pipe but without pulling loads of bits out I can't get a clear shot of it.
