CUP172 - REAR BRAKES - ONLY ONE RECEIVING FLUID
  RS Clio Cup172
I have read a few posts about similar issues but nothing quite what I need advice on.
My car was having new brake lines fitted and when I went to collect they told me only one line at the rear received the fluid. They thought it was possibly the brake valve causing the issue as they rechecked the lines and all were okay, but I arrived when to collect at that point.
My rears discs and pads were only changed in December by my local garage.
I'm drove the car back home (almost 2 hrs) and want to take to my local garage to resolve (they know my car as they did the rear brake discs / oil change etc) however what specifically does this model have different from the later 182's...anything? Has anyone had the experience where one rear line filled with fluid and the other did not?
Any advice is appreciated.
npt
  BMW 320d- 172 cup
Spray some wd40 on the valve and work it up and down, most get sticky after a while.
The valve needs to be in the up position to get fluid through the valve, you'll only get a little if the axle is hanging down with car jacked up.
You can tie wrap the valve closed while you bleed it
  RS Clio Cup172
The car had all new rear brake lines. The rsports specialist said they are sure the issue is a blocked valve - to the passenger rear, although the other rear brake was successfully drained.
I've read there's a valve between the wheels but that's all i know at the moment.
16v_paddy
  Valvers & 172 Cup
That only applies to non- Cup though as those are linked to the rear beam, on the 172 Cup that bit isn't connected so the rear braking effort is fixed
It's 100% the valve at fault, it might be worth trying to remove the pipes either side of it for the caliper that isn't getting the fluid and blasting it with compressed air on each side to see if it dislodges anything, failing that you'll need a new one. I got mine from Euros but they quite often disappear & reappear in stock there as well as Autodoc which is showing them as in stock https://www.autodoc.co.uk/bosch/671793
npt
  BMW 320d- 172 cup
Yes but the valve sags a little over time on the cup, there's not much can go wrong inside the valve block apart from it getting a little seized, it's very common for them to need some hands on to get them working after a few years, try it, it'll most likely work
npt
  BMW 320d- 172 cup
Would I need to remove the valve to clean it up and what is best to use or should I leave to a mechanic?
I just sprayed mine with wd40 and worked it up and down without taking it apart last month, had the same issue you had, worked it a good while and it's back to working fine, they basically never move much which is the issue.
I've had mine coated in wax a few times in the last 10yrs which has helped keep the rust/salt from getting to it, be much easier just fitting an internal bias valve 😂 french sh@t
  RS Clio Cup172
The prices for these has gone way too high, mines in visible good condition no rust, so I will print these tips for the local garage to try and also check the new brakes lines / fluid that were fitted by beaniesport. They also need to refit my exhaust as that was not put back on right after new clamps were fitted by BS (currently hanging down lower than the rear bumper) :/
Matt Cup
  Iceberg 172 Cup
Oh…
  RS Clio Cup172
UPDATE
My local garage had the car today and confirmed I have to replace the valve - they cannot get fluid through to one rear brake line.
HELP:
I have found a bosch part online however they do not list it being compatible with my CLIO CUP 172 2002 only from 2004 models...
RUK have no stock of the valve.
Who or where can I either get mine repaired (?) or does anyone know of a part or any technical info that can help me use a 182 trophy valve for example (or will that create potential locking rear brakes?
Thanks alot for any tips and advice in advance - I need to keep my CUP going through its 24th year in my ownership
Mr Trailer Man
UPDATE
HELP:
Are they not the same valve, just with the big spring and rod removed?
Matt Cup
  Iceberg 172 Cup
Mines connected 🤷🏻‍♂️
  RS Clio Cup172
I've heard the cup factory fitted are non adjustable which is why they produced a VOSA technical sheet for MOT's.
I'm happy to fit one with a spring although I don't know how Renaultsport changed the rear braking specs for later models 172, 182, 182 trophy etc The only way to check RUK parts is with car reg of those models.
Matt Cup
  Iceberg 172 Cup
This might be a hazy memory but I’m pretty sure I have read on here people have completely bypassed the valve and re-routed some brake pipes back to the m/c.
Matt Cup
  Iceberg 172 Cup
Edit here it is using a brake bias valve but no one concluded the thread.
16v_paddy
  Valvers & 172 Cup
UPDATE
HELP:
This is one of those occasions where the information online is all completely wrong - that Bosch valve is the same part as fitted to other 172's (but not all 172's have it) and the only thing you need to do to make it correct for a Cup is completely remove the rod & spring from it
16v_paddy
  Valvers & 172 Cup
The "official"-ish term is fixed bias rather than non-adjustable which is because of the Cup not having the valve connected to the rear axle - you can actually adjust the valve itself by undoing the big lock nut and turning the inner thread bit with a 5mm allen key - deffo a bit sketchy to be playing around with it unless you're trying to be really really anal with the setup and got the use of a brake testing machine at an MOT place
  RS Clio Cup172
I've seen some bosch valves on ebay but none match the renault part number for the cup.
Does anyone know if the Bosch can work or be fitted to the cup brake system (or easily modified to work)
as it's over 50% less £
Thanks again
16v_paddy
  Valvers & 172 Cup
Renault are absolute arseholes with chopping & changing parts numbers so on anything over 10 years old it's not always a reliable thing to go by.
Another cnut's trick Renault like to pull is having almost completely identical parts with different parts numbers because 1 of them comes with a bolt or something stupid like that - rear discs are a brilliant example of this - I wouldn't be surprised if the bias valves are the exact same parts for 172 and 172 Cup but the Cup 1 has a different part number because it doesn't come with the rod & spring
From when I had the exact same problem on my Cup, as far as I could find out or tell, the Bosch part was the only 1 that existed. I got it from Euro's which just happened to say it fits my car based on the reg but plenty of other places online were saying it's wrong or doesn't fit but that's what I fitted to the car, chucked the rod & spring in the scrap pile and it's all good now.
As bad as this issue is with the Cup braking system, it's at least 10 times worse if you need a servo or master cylinder 😂
