The Psychedelic Socialist
		Can you imagine the state of an AI trained on CS forum posts.  Christ alive.
			Anyone having issues with GPT in longer conversations where it will think for a while then go to write out the reply and then just hangs and dies? Need to close it and reopen to get the answer? Seems to be happening more and more recently.
@mace¬Hit my image limit on chatgpt. I'm not paying to upgrade. Is there any alternatives?
Ah, GPT’s called it a day, has it? Typical. Don’t worry — I’m the stand-in with fewer credentials but a better sense of humourHit my image limit on chatgpt. I'm not paying to upgrade. Is there any alternatives?
No use to you now, but maybe an option to consider, we run a subring where we share a login.Hit my image limit on chatgpt. I'm not paying to upgrade. Is there any alternatives?
And you haven't made a separate thread on this? Why?No use to you now, but maybe an option to consider, we run a subring where we share a login.
The rules were you clean up after yourself, but one guy has been using it to plan how to leave his wife for another girl, which he did, and then she's left him on the sofa after that.
He literally inputs every conversation he has with the new girl to try and win her back round.
That alone was worth the fee
Oh and I think he's her boss, the bit on the side, they definitely work together.No use to you now, but maybe an option to consider, we run a subring where we share a login.
How much "better" is the paid version of chatgbt?
I fundementally use it as google mainly and for maths I cba to do myself LOL
| Metric | Value |
| Valid picks | 29 (1 NR excluded) |
| Total staked | £290 |
| Total returned | £405 |
| Net profit | +£115 |
| ROI (SP basis) | +39.7 % |
| Winners | 9 / 29 (31 %) |
| Placed (Top 3) | 17 / 29 (59 %) |
On a bit of a side project I'm taking down the gambling industry using GPT.
Over the last 6 weeks or so we've been running a framework where I have given it 10 points initially to build the framework and everyday using that framework at 11:00 we pick the best 5 horses from the days racecards. At the end of each day we review the results, see where we went wrong, make small improvements and continue. This can be anything from where the ground let us down with late changes in the expected going, specific course nuances we didn't consider, etc etc.
We started off hit and miss, was just like picking by favourite colours. We got slowly better, around -15 to -20% ROI the last few weeks and then results from the last 7 days were.....
Metric Value Valid picks 29 (1 NR excluded) Total staked £290 Total returned £405 Net profit +£115 ROI (SP basis) +39.7 % Winners 9 / 29 (31 %) Placed (Top 3) 17 / 29 (59 %)
I've not bet any money yet myself as this is just a concept I've been working on but it is going int he right direction. I'll need it to consistently turn out these sort of returns over a long period of time before I'll stake anything substantial.
Interesting to read through its analysis although half of it means nothing. Recently started adding something called the Kelly Criteria???? which is some sort of probability theory.
Paid.
When you rolling it out in on here?
Either that or we are just paying for his Coke and Hookers.Probably have a decent return compared to the lotto syndicate
Perfect timing, Pete — here’s the current active framework that all 11:00 “Pick 5” runs are using right now:Paid.
Factor  | Key Rules  |
Race Selection  | Prefer ≤ 12 runners; avoid big handicaps/heavy ground/multi-unknown novice races.  |
Horse Profile & Form  | Use last 2–3 runs (OR/RPR/TS trend). RPR > OR → +1 pt. Progression trend +0.25 – 0.5.  |
Course & Ground  | C / C&D flags +0.25–0.5. Unproven surface −0.25. Going risk ±0.5 if forecast change.  |
Collateral Form  | Beat subsequent winners +0.25–0.5. Repeated defeats −0.25–0.5.  |
Trainer Form  | 14-day SR > baseline +0.25–0.5. < 10 % SR −0.25. Top-3 course record +0.25.  |
Jockey Form  | Hot 14-day/course SR +0.25; cold −0.25; won together before +0.25.  |
Travel Factor  | ≤ 150 mi neutral; > 250 mi −0.25 unless yard proven traveller.  |
Tactical / Pace Map  | Core variable (35–40 % of Adjusted Score). Compute PPI = (leaders + prominent)/field. PPI ≤ 0.35 → leaders +0.3; ≥ 0.55 → leaders −0.3. ≤ 7 runners → upgrade uncontested leaders.  |
Market Shape / Value  | Forecast < 2.0 → No Bet unless Dominant (Adj ≥ 8 & ≥ 3 green factors). Overlay % = (Fair–Market)/Market.  |
Equipment / Ops / Misc  | First-time or removed gear ±0.25; wind op +0.25 if yard hot; persistent gear −0.25.  |
