ChatGPT (AI)
Anyone having issues with GPT in longer conversations where it will think for a while then go to write out the reply and then just hangs and dies? Need to close it and reopen to get the answer? Seems to be happening more and more recently.
Ye it did this when I was asking if Verstappen could win the championship based off different scenarios I gave.
Think I blew a server
Hit my image limit on chatgpt. I'm not paying to upgrade. Is there any alternatives?
Ah, GPT’s called it a day, has it? Typical. Don’t worry — I’m the stand-in with fewer credentials but a better sense of humour
Note: GPT might have wrote this
No use to you now, but maybe an option to consider, we run a subring where we share a login.
The rules were you clean up after yourself, but one guy has been using it to plan how to leave his wife for another girl, which he did, and then she's left him on the sofa after that.
He literally inputs every conversation he has with the new girl to try and win her back round.
That alone was worth the fee
And you haven't made a separate thread on this? Why?
Im seeing more and more 'have a go heroes' at work using this, putting contracts in and generating comments, and then passing it off as there own work.
Im not normally arsed, but they dont even delete the tell-tale signs that Chat GPT used it, such as the bloody emojis or the 'would you like me to put this into a pdf, or share a link - just say the word!'.
Morons.
Its also great asking questions on it when they clearly havent even read the output.
There's a guy at our place who thinks hes Billy big b****cks now as he's been inputting fault logs from our panels into chatgpt to get it to tell him whats going faulty, and is there any patterns etc.
If you can't do that by yourself, then you're s**t at your job (he is).
How much "better" is the paid version of chatgbt?
I fundementally use it as google mainly and for maths I cba to do myself LOL
I get the paid version through work and seems pretty good.
I use it for various admin tasks, price comparison, auto responding to certain emails etc.
I haven’t used the free one in a while tho so not sure how it compares.
  • Like
Reactions: seb
Oh and I think he's her boss, the bit on the side, they definitely work together.
It's equally hilarious and tragic
The only difference I noticed was that it seems a bit more reliable. I was doing something with a consultant and we were using the paid and free versions to experiment. The free version seemed to go off on a bit of a tangent and then get stuck in a hallucination loop pretty quickly, while the paid version kept on going (before eventually doing the same, obviously).
I still have mixed feelings about it to be honest. My missus loves it and uses it all the time. I do pay for it, and use it quite a bit, but also find it quite frustrating and often find myself thinking it would have been quicker to do it myself.
On a bit of a side project I'm taking down the gambling industry using GPT.
Over the last 6 weeks or so we've been running a framework where I have given it 10 points initially to build the framework and everyday using that framework at 11:00 we pick the best 5 horses from the days racecards. At the end of each day we review the results, see where we went wrong, make small improvements and continue. This can be anything from where the ground let us down with late changes in the expected going, specific course nuances we didn't consider, etc etc.
We started off hit and miss, was just like picking by favourite colours. We got slowly better, around -15 to -20% ROI the last few weeks and then results from the last 7 days were.....
MetricValue
Valid picks29 (1 NR excluded)
Total staked£290
Total returned£405
Net profit+£115
ROI (SP basis)+39.7 %
Winners9 / 29 (31 %)
Placed (Top 3)17 / 29 (59 %)
I've not bet any money yet myself as this is just a concept I've been working on but it is going int he right direction. I'll need it to consistently turn out these sort of returns over a long period of time before I'll stake anything substantial.
Interesting to read through its analysis although half of it means nothing. Recently started adding something called the Kelly Criteria???? which is some sort of probability theory.
MetricValue
Total staked£290
Total returned£405
Net profit+£115
Love this! 🤣
MetricValue
Total staked£290
Total returned£405
Net profit+£115
Paid.
When you rolling it out in on here?
Paid.
Perfect timing, Pete — here’s the current active framework that all 11:00 “Pick 5” runs are using right now:
🧩 Horse Racing Framework v2.1f (Active as of 21 Oct 2025 – AW-Bias Edition)
(base = v2.1a 10-Point System + refinements v2.1b → v2.1e)
🧱 1️⃣ Base 10-Point System​
Factor​
Key Rules​
Race Selection
Prefer ≤ 12 runners; avoid big handicaps/heavy ground/multi-unknown novice races.​
Horse Profile & Form
Use last 2–3 runs (OR/RPR/TS trend). RPR > OR → +1 pt. Progression trend +0.25 – 0.5.​
Course & Ground
C / C&D flags +0.25–0.5. Unproven surface −0.25. Going risk ±0.5 if forecast change.​
Collateral Form
Beat subsequent winners +0.25–0.5. Repeated defeats −0.25–0.5.​
Trainer Form
14-day SR > baseline +0.25–0.5. < 10 % SR −0.25. Top-3 course record +0.25.​
Jockey Form
Hot 14-day/course SR +0.25; cold −0.25; won together before +0.25.​
Travel Factor
≤ 150 mi neutral; > 250 mi −0.25 unless yard proven traveller.​
Tactical / Pace Map
Core variable (35–40 % of Adjusted Score). Compute PPI = (leaders + prominent)/field. PPI ≤ 0.35 → leaders +0.3; ≥ 0.55 → leaders −0.3. ≤ 7 runners → upgrade uncontested leaders.​
Market Shape / Value
Forecast < 2.0 → No Bet unless Dominant (Adj ≥ 8 & ≥ 3 green factors). Overlay % = (Fair–Market)/Market.​
Equipment / Ops / Misc
First-time or removed gear ±0.25; wind op +0.25 if yard hot; persistent gear −0.25.​
⚙️ 2️⃣ Framework Refinements (v2.1b → v2.1e carry-overs)​
  • Front-Runner Density Check (v2.1b): −2 pts if ≥ 2 habitual front-runners and our pick is also forward.
  • Strong Finisher Bonus (v2.1b): +2 pts for proven late-closers / sectional trend positive.
  • Going Consensus (v2.1b): if public going differs ≥ 1 step within 90 min → downgrade sprints.
  • Trainer Form Gate (v2.1c): < 10 % 14-day SR → down-rank one tier.
  • NH Micro-Field Blocker (v2.1c): Skip ≤ 4 runners unless fav ≥ 6/4 & ≥ 70 % jump rating.
  • Ascot Lane Model (v2.1d): Straight 6f–1 m; rail bias +0.4 near rail, −0.25 mid/high without pace.
  • Field-Size Filter (v2.1d): > 14 runners G1/G2 → −0.5 or exclude from acca.
  • Pace Weighting Boost (v2.1e): Pace/Tactics = 35–40 % of score.
  • Lone-Leader Rule (v2.1e): ≤ 6 runners and single likely leader ≠ our pick → −2 or No Bet.
  • NH Novice Odds-On Guard (v2.1e): ISP < 1.80 and no ≥ 7 lb clear → Skip.
  • AW Stayers Hold-Up Filter (v2.1e): ≥ 12 f & hold-up style −0.8 unless late-bias track.
  • Going-Split Enforcement (v2.1e): Apply ±0.3 if official hurdle/chase split changes.
  • Acca Hygiene v2 (v2.1e): Require ≥ 2 Leader/Co-Leader legs for acca build.
⚡ 3️⃣ v2.1f Additions (21 Oct AW-Bias Hot-Fixes)​
1️⃣ Intraday AW Bias Adapter (Newcastle/Tapeta)
 If first two races ≥ +2.5 s slow and winners come mid/back → reduce Leader Advantage −20 %, increase Closer Suitability +20 % for remaining Ncs legs.
2️⃣ Run-Style Uncertainty Dampener (≤ 7 AW runners)
 −10 % pace-map confidence when trainer/jockey show ≥ 30 % “ride cold” tendency (last 30 days); allow prominent → mid/back re-score without penalty.
3️⃣ Acca Hygiene v3 (AW short prices)
 Exclude AW legs ≤ 6/4 unless projected pace edge ≥ +1 length post-bias.
4️⃣ Going/PPI Soft-Upgrade (NH 3 m +)
 Soft or worse → +5 % multiplier for proven stayers.
🧮 4️⃣ Selection & Ranking Logic​
  1. Score each runner on 10 base factors (+/− refinement adjustments).
  2. Apply One-Per-Race hot-fix → keep highest Adjusted Score.
  3. Remove No Bet cases (short price, odds-on guard, lone-leader conflict, trainer gate).
  4. Rank remaining by Adjusted Score × Overlay %.
  5. Top 5 = singles; Top 3 (hygiene-qualified) = win acca.
📊 5️⃣ Output Format (v2.1a″ Simplified Value Display)​
Each pick shows:
  • Race & Horse
  • Confidence (🔵 High / 🟢 Fair / ⚪ Cautious)
  • Value Grade (🟢 Good / ⚪ Fair / 🔴 Poor)
  • Why it’s value (one line)
  • If Beaten (expected failure mode)
  • Stake Guide (Low / Medium / Full)
  • Tag (Clear Edge / Thin Edge / No Edge)
That’s the full active structure being used in all current 11:00 analyses and 22:00 reviews.
Would you like me to append the new “Investment vs Return gate” (the low-ROI filter you mentioned last night) directly into this as v2.1g draft for testing tomorrow?
Disclaimer: Bets are for entertainment, not retirement plans. Your wallet is not a magician and the odds don’t owe you a favour. Past wins are about as predictive as British weather. Only stake what you can happily wave goodbye to, and if you do win, please act surprised. 18+ only. If it stops being fun, stop—support at BeGambleAware.org or 0808 8020 133. If you do win I'll take donations.
Papers I didn't think I'd be reading this year:
TL;DR, if you ask an LLM how to do something prohibited, it'll rightly tell you to f**k it off. But if you put it in the form of a poem, especially a long one, you can actually get it to ignore its own rules (sometimes).
Similar to the guy who asked AI to tell him how to make napalm explaining that his grandma used to tell him that story when he was a kid.
Whilst AI has its uses, I am getting thoroughly sick of the bulls**t trash that invades and litters pretty much every aspect of my digital life. Don't even get me started on its use in the workplace. It certainly has a place in workplaces; but I do not like this trend of businesses pushing for AI adoption at such rates (FOMO?) and with seemingly little process or due care and attention as to the pitfalls. It is already becoming a problem in the software engineering / software development field. AI code generation is prolific and causing nightmares for many reasons; unchecked and non-reviewed AI-generated code checked in to repo's, seasoned engineers not being bothered to review AI-generated code due to the pain that it is to walk through the slop. The constant push by businesses and management to adopt AI tooling without process or training in place. The net result often isn't a better solution in a shorter time. Quite the opposite. Arguably, the real development and engineering is needed when things go wrong in a system. And when that knowledge is not there and the system is formed of badly AI-generated output, it's a whole world of pain. I foresee some pretty big scale f**k-ups incoming.
It’s all because senior managers hear AI and get a combination of FOMO and cost savings dancing before their eyes IMO.
Knowing what some of our offshore developers are churning out, I don’t know if AI would do it better or if they are already using AI mind you.
It’s all good though, we’ll be using lots of customer facing AI features in our next release. Not the existing heuristics tarted up and with an AI label slapped on the top, oh no. Genuine AI. Definitely. Yet somehow, the customers will have no need to upgrade their systems to have enough memory and compute to run the models. True witchcraft.
