Martin_172
I've got a problem with my sisters (no!) Twingo 1.2 16v currently, pretty much identical mechanically to a mk2 1.2 16v Clio.
she's owned it for years, gave very little issues, it went for an MOT last month, the test station abandoned the MOT as during emissions it started uncontrollably revving its self, they turned it off and back on and as soon as it started it continued to keep revving its self, up above 4500rpm.
It came to me, I checked it over and did notice a few things:
With both of these replaced, the "fault" is still present.
I've ran it for a couple of weeks with no issues, so today put it into another garage for an MOT, My usual garage this time. Just had the phone call to say they have had to abandon the mot as during the emissions test its started uncontrollably revving its self.
Thoughts?!
- It had a slight misfire at low throttle, I put plugs, coil pack, leads on it, problem solved.
- when cold started, it idles as normal at around 900rpm, if you touch the accelerator it will rev then settle at around 1500rpm for around 10 seconds, then drop back to idle, identical each time as if its programmed to do so (but I know it isn't)
- once its up to temp it just idles at 1500rpm
Thoughts?!
