Jamesmills182
Renault Clio 182
How often dose the gearbox oil get changed cause I can’t see in the paperwork I got with car has it done?
I believe the 200 has a 6-speed box, the 182 is a 5 speed, so probably not the same box (or casing). I drained 3 litres and put 3.1 back in but it never poured out the filling hole, but happy to go with the recommended amount.I assume this is a 182, but I did my 200 recently. Fill plug is a wing nut on the side of the box. Jacked car up, wriggled around and was able to access. Made sure I could undo before draining.
Drained on slightly warm engine. I measured the drain, just under 2 litres. I got some GL4 75/80 elf stuff off eBay for about £30.
I trimmed a garden hose as unadjusted it didn’t quit fit. I pushed the end of the hose in and gravity fed via hose and funnel 2 litres.
The fill plug is supposed to be the over fill point, but none was particularly dripping out when I did mine, and I didn’t want to open litre 3.
I assume the 182 is the same.
Handy info in this thread.
Can the gearbox oil level be checked via access through the filler port?
I’ve got an endoscope camera - could use that.Yeah but you'd do well to see it by eye.
Best way to tell is if you open the filler and fluid trickles out.
Could use a bore scope if you had one.
So it should weep/trickle out like you say when the filler screw is slackened off?
