182, no spark no fuel non starter !!
  Clio 182, Corsa VXR,
So I cannot for life of me figure out why it won’t start. I’ve replaced the crank sensor with the blue type and plug, I’ve also replaced the coil pack with a Lucas, new battery and all earth straps are not broken, immobiliser light is normal and light goes out after a few seconds. Checked all fuses and relays all good. I’ve no power to the fuel pump or coil pack plug and no power to the fuel pump relay???? Is the wiring to the crank sensor fed from the ECU ??
npt
  BMW 320d- 172 cup
There is a 5amp fuse in the engine bay for the pump, try thst first
