bvnditi
Yeah that's the same size mate uses.
Duly noted.
In that instance, just don't strap Wilwoods to your 200T and you're mint then basically.
Presumably you mean Foxy? I was on RP1’s mateCan only think it's the tiny pads they use.
Both guys I know who were at CSF in Porsche and BMW both use RPX and get on really well with them.
Lol.
No offence, but doing a few laps of the ring road at midnight, is not a comparable experience to running a car on track.
It’s also, frankly, childish.
Whole reason I'm now moving onto track stuff and have an instructor session booked at Curborough.
The use was a little bit more protracted than that and comfortably away from civilisation, but aye
It's more matching the swept area of rotor and pad to suit the vehicle and what you're using it for.Bloody good to know, and shall enjoy Curborough.
So don't buy ancient Wilwoods with tiny pads and strap them to your 200T, basically.
Also massive apologies @Rojer as I have unintentionally derailed the everloving s**t out of your build thread with my poor caliper choices
Proper boring youLol.
To add I bought my 2nd set of RP1's recently, went to install to find my existing 6 track day old RP1's were just about half worn... changed nothing and did Cadwell, they are still perfect.
Plus 1500-2k of road use. Disks don't even look worn. I reckon thats pretty amazing.
They don't do RP1 for my standard caliper so it's either DS1.11 or Winmax W5. Both are highly rated, but I have heard the W5 have a crazy long life and better pedal feel. Probably go with 2500 in the rear.
Have you run DS1.11 front and rear ever? Or are they not available for the rear?DS2500 will be ok in the rear with DS1.11 in the front.
I run PBS rear and SR11 front.
I ran W5 in the Clio and would probably go W6 if had them again.
I kind of get it on a 172/182 as they are so light at the rear some people say they can't get enough heat into the rears. On the Mini for the first track day I ran different pads and it was horrible.
DS1.11 and 2500s ordered. Just need to order some new lines.
May as well change fluid for Castrol SRF while you're there![]()
I run ds1.11 front/2500 rear, no issues. Its a tried and tested combo on megane anyway.Have you run DS1.11 front and rear ever? Or are they not available for the rear?
Prob not worth the extra money. I only went for ds2500 rears due to doing in a stock set of rear pads to metal in half a day. Ive had 2 days out of ds2500 and still 3/4 left.Wonder if its worth trying the 1.11's on the rear now they are available?
Bit off topic but just had a sniff round for meg ds1.11 rears and about £230 a set if you can get them.
Kam racing says
Ferodo are one of the most popular choices for the Renault Megane RS225 and R26. The DS2500 work as a great all-rounder for both fast road and light track use. The choice of avid trackday drivers is the Ferodo DS1.11 front brake pads with DS2500 rear pads but we think the rear can benefit by using DS1.11 on the rear as well when using a firm suspension setup which reduces weight transfer forward under braking.
Might be worth a punt i guess, ill wear this set out first.
Kangoo really needs uprated rears after the brief run round anglesey a few years ago. I cant get any rear pads and my planned rs rear brake setup is shelved. Might get a set of winmax rears made up for it in similar compound. Kev/kam racing said they will make custom pads.
Interesting cheers mate, ill have a look into it.Carbotech will make you pads with your old backing plates too.
RST3/RS44 was a mint combo in the Megane tbfYou should not mix pad types at the rear unless you are deliberately trying to shift balance.
On the VX/Elise people do it deliberately sometimes to get more rear bias but it's a s**t fix as then the rear initially have more bite that the fronts when cold then go off faster than the fronts when hot.
Im going for bluestuff on the back of my megane, more than good enough for the job and wear well, £100 to your door which helps too
Oh dearJust for info, Bluestuff lasted 2 trackdays on the rear of my 250![]()
I might get them instead thenPBS ProRace not much more are they? That's what I use and they hardly wear.
Did you have traction & esp turned on?
