Megane RS250 - Infuriating airbag light
Fishfire
Car  Clio 172
RS 250 Airbag light still on after cleaning connectors & refitting seat rail microswitch – does it need clearing?
Hi all,
Appreciate this is for a Meg but the community here is so good I thought the renault ninjas here may be able to offer some advice/help!
Looking for a bit of advice on a persistent airbag light on my Megane RS 250.
An ECU scan flagged a fault with the driver's seat side airbag.
Leading up to this, the airbag warning light used to be completely intermittent—it would come on randomly, go off for a while, and then come back on randomly. Now, however, it's stuck on all the time.
While investigating under the seat, I found the seat position microswitch dangling loose off the rail.
While I had access, I did the following:
- Reinstalled the microswitch back onto the seat rail properly.
- Cleaned all the under-seat electrical connector blocks and pins with electrical contact cleaner.
- Checked all the wiring thoroughly for any pinches, chafing, or wear—there is nothing obvious, and the wires all look completely fine.
- Disconnected the battery for well over an hour to let the system discharge before bolting everything back together and reconnecting.
Despite all that, the airbag warning light is still on solid.
Does the airbag ECU need the fault code manually cleared with a scanner after fixing a side airbag circuit issue, or should the RS 250 self-clear the dash light once the resistance is back in spec?
Given the history of it being intermittent before staying on permanently, I'm wondering if a stored code is holding it, or if a pin/internal break is still dropping out of spec.
Any help or pointers appreciated!
You will have a fault present. The fault will clear automatically when the fault is fixed, i.e. the line that is not showing the correct resistance.
Use diagnostics to trace the isssue, looking at firing line resistances. All should show 2-3 ohm when correct.
Was showing as side airbag drivers seat (fault report att.) Checked the plug and wire that comes direct from that airbag, as well as the main SRS yellow plug, but theres nothing obvious
*deep sigh
4 srs faults stored by looks of it. You will need to see whats left.
Has it had seats changed before?
Still standard seat. A mechanic mate has just been round again with his ecu scan tool, and its showing 0 impedance for lines 9, 10, 11 and 12. One of those is the ABS (which also has a fault on full wheel lock) so potentially if they share a common ground, that may be the issue. Maybe 🤷‍♂️
