Cutting out????
Car  2001 Ph1 172
last nite i was driing my ph1 172. Every now and again it would cut out! its alaways at low revs ether pulling awat or sat with the clutch down??
it only seems to have been happening since renalt serviced it on Tuesday?
my cam belt is due and causing a slight uneven to the idle, will this cause my problem??? HELP please!
i doubt the uneven idle is caused by an overdue cambelt (that usually causes uneven valves LOL)
maybe damp?, maybe reno put new plugs in it and did'nt replaced manifold gasket & 'o' ring and its sucking air?
im sure they didint do the plugs as its only 48000 service plugs are 72000 i think!
No they defo didnt do the plugs! and ive been driving it today and whey im moving with low revs it stutters and jumps? i know on older cars thats usaly an issue with igion stuff any ideas???
Could be a number of things I'd check the coils.
do u guys think i have a case to return it to renault? as it wasnt doing it before?
