BenWall Car Fiat Panda 100hp Nov 16, 2006 #1 I having real issues with newsleecher. Keeps locking up. What else do ppl use?
Griff Car 172 Cup Nov 16, 2006 #2 Re: hindernce to newsleecher?? Have you tried to exceed the trial period by any chance? Try Grabit - http://www.shemes.com/index.php?p=download
Griff Car 172 Cup Nov 16, 2006 #4 Re: hindernce to newsleecher?? Thought so.. Newsleecher doesn't respond well to attempts to crack it and will stall every 5 to 6 minutes.
BenWall Car Fiat Panda 100hp Nov 16, 2006 #5 Re: hindernce to newsleecher?? Ok thanks, ill use that one as its free. Do I use the username and pass that worldpay have sent me from NewsDemon?
Griff Car 172 Cup Nov 16, 2006 #6 Re: hindernce to newsleecher?? The username and password sent by Worldpay is to log into your Worldpay account (to change payment details, access receipts etc) The username/password you need will come from Newsdemon directly, something like "Welcome to Newsdemon.com"
BenWall Car Fiat Panda 100hp Nov 16, 2006 #7 Re: hindernce to newsleecher?? I think I have finally got it working. Last edited: Jan 30, 2007
Griff Car 172 Cup Nov 16, 2006 #8 Re: hindernce to newsleecher?? Nice one. Just check you've set it to 8 connections rather than the default 1.
BenWall Car Fiat Panda 100hp Nov 16, 2006 #9 Re: hindernce to newsleecher?? Okay. Thanks for all your help Griff!
sargey Car Astra CDTI SRI Nov 16, 2006 #10 Re: hindernce to newsleecher?? .Griff. said: Thought so.. Newsleecher doesn't respond well to attempts to crack it and will stall every 5 to 6 minutes. Click to expand... edit your host file (C:\WINDOWS\system32\drivers\etc) with notepad and stick this line at the bottom........ 127.0.0.1 www.newsleecher.com This will stop it locking.
T Tim-Grove Car Leon Cupra Nov 16, 2006 #12 im still using V1.0 of newsleecher as its the only version i can get to work cracked
BenWall Car Fiat Panda 100hp Nov 16, 2006 #13 Im using GrabIT and the mo. Is there any benifits from using newsleecher?
sargey Car Astra CDTI SRI Nov 17, 2006 #15 Tim-Grove said: im still using V1.0 of newsleecher as its the only version i can get to work cracked Click to expand... Get v4.7 and crack it then add the line that I talked about above and it should work fine
