HD LCD tv's.....Blurry
J273
Car  RB 182
Just got a HD tv....and am running normal sky through the tv not Hi def and find the picture really blurry ......Is this the case with all LCD tvs blurry and ghosting? if watching anything other than HD
Jamie
well the tv i got aint exactly the best ....its only a cheapo goodmans £350 from tesco but works great with the 360 ....didnt know if this was the norm with all lcd tvs
tbh most arnt great with sky as they bandwidth they use is pap and they compress teh hell out of everything
but the smearing and ghosting is more likely to be your tv
Ahhh ok....So if this pictures sorta pixelated.....is this due to the tv as well or the source?
Thanks
yea its like the pictures been blown upto much....if you get what i mean?
possibly mosquito noise too
mine is terrible on normal TV
on freeview its pretty good but watching football on it is still pretty bad (ghosting around the players/ball) although still very watchable
Heres a few ...not the best##
What scarts are you using? If its a crappy black colour jobbie from a normal electrical store then yes id say so, mine used to be like that.
Like i say why people buy expensive hdtvs then use crap equipment to connect it i'd never know.
You wouldn't buy a ferrari then stick halfords oil in it would you, same principle ;)
that middle pic does look rough............
have you slected rgb input off the scart..
I find on mine thats the best looking input off the scart
An RGB scart gives the best quality picture because it only carries images and not sound meaning there is less chance of interference within the wire.
If i select the RGB output on the Sky settings my picture goes piss poor, its sharp using my RGB scart and having it set to PAL tho
Yea cheapy black 1s
How do i go about outputing rgb from sky?
Thanks
Yea cheapy black 1s
Thanks
Press your services button then select system setup then picture settings
you change it in there
So is there an optionwithin the sky menus to outpu RGB?
what other settings are best to use from the sky config?
Sorry not much of an idea on this sort of stuff
Thanks
The settings ove got are
Picture format: 16:9
Second location picture:4:3
Scart control:ON
Video output:RGB
Contrast:MEDIUM
Tv is watchable though....cant really complain for £350
If its already set to RGB just try changng it to pal and see what difference it makes
Ok matey.....Ill have a play with the settings...find whats best
Thanks guys for the info
