im not a mechanic and dont know anything about cars.
my car seems to whine in a straight line, not so bad at 60, but from around 30 to say 50 its whinning. now i, guessing the discs are warped, am i correct or completly wrong? :lolup:
I had the same thing happen with my Megane. It was under warranty, I think theyt replaced the power steering pump or something! Exactly the same symptoms though...
03 plates have electric power steering normally if theres a fault with it the light will come on on the dash. checked your tyre pressures? could also be tyre related.
look the the fluid from under the car, if it seems quite 'clean' looking, its most probably power steering fluid. check the level in your power steering fluid reservoir under the bonnet.
am i being thick. with the electric steering. does it still have power steering fluid, i looked in the haynes manual to see where it was and it werent where it said it was...so do they use fluid?
