Leak (continued)
  • Thread starter Thread starter thecremeegg
  • Start date Start date
T
thecremeegg
Rite, the scenario continues....i thought id fixed the leak with sealing round the sunroof but no....its back
the front drivers footwell, rear drivers footwell and rear passenger footwell are soaking again. this is gettin me really concerend now due to smell and condensation. can anyone help? im worried that taking it to a garage will be expensive as they'll have to spend a lot of time diagnosing whats wrong
any help very much appreciated as i cant afford a new car
Tom
what should i be checking with the window seals, just that they're damp?
as for the bungs underneath, had a look and all seem well stuck in....is there any other likely area underneath that is prone ot leaking?
Tom
Yep see if there any holes.
The holes in the scuttle panel to the car dahsboard are can leak so check them but you migth need to remove the Polen filter etc to check
Also check the door seals for rips etc. Best idea is to strip as much out rh car as you can and get someoen to wash the car whilst you sit inside it.
