You can fit it, but it won't do you nothing exept for the noise.
Dumpvalves are used to let the pressure out of the space between the turbo and the Throttle body, when you put your foot off the gas pedal.
But diesels don't have TB's so there is never that build up of pressure
Dunno if I made myself understood![]()
Do you know where does it come from?
Didn't have time to check it yet :-\
Cheers,
J!
So... manifold -> tube -> MAP?![]()
That hose that is marked. Can you connect the dump valve to that? I have a DCi 65?
