firewalled?
when uploading and downloading off azeurius it says firewalled and has stopped, now it wont do anything??????????
i have disabled norton but still nothing??? help me please!
Check your Windows firewall. Are you working behind a company firewall? If so, traffic will be restricted, i.e. No music :p
Have you tried rebooting your computer?
yea re started it, nothing, i have got it working now but have gone from 220kbs to 700bs?!¬?!?!?!?!?!? im working from home and have bnever had problems like this before/
Could be a problem with the network itself, too many user's utilising the network. I had a similar problem when using LimeWire. But mine stopped, it would not connect. Should clear by the evening. If it doesn't get a diff P2P :rasp:
Hope this helps!
Are you using a router? If so you will need to use port forwarding for the port that you are using for the application (Azureus)
now using utorrent, says 49.3 kbs ( total 2.1mb) ??????? what does this mean and why is it so slow, was getting 200kbs plus on azeurus?
the P2P network run off the pricible of the more users on with the file you want the quicker you can download, if using torrent files you need to look out for seeders this will mean you can download faster.
Stuart
