What size steelie would fit my 172?
len_beach
Car  E92 M3,172 track car
I want to remove the spare alloy in order to reduce weight but I don't want the risk of no spare. What size steelie would fit over the calipers of the 172?
Anyone any ideas what car I could get one from?
Let me get this straight, you're going to replace your alloy spare wheel with a steel one to save weight?
Changing to the same size steel wheel isn't going to save any weight. And changing to a smaller steel wheel and smaller tyre isn't going to save enough weight to make a noticeable difference. Even removing the wheel altogether is only going to save 18 kgs. Which is only worth about 0.05 seconds in 0-60 time or quarter mile.
I'm not looking for a 16'' steel wheel, I was asking what size steel would fit. Bearing in mind that a 172 wheel weighs the best part of 18kg as you said, I find it very hard to believe that a similar size if not smaller steel wheel would weigh nearly as much.
Tyre foam is not an option unfortunately as I just don't trust it.
14 would fit on the back but if you have a front puncture you've have to swop front to back and put the spare on the back.
Same as the Civic CTR owners have to.
Super, I have a 14'' Vauxhall steel in the garage. I'll give that a dabble.
