quick guide
*** the clutch pedal has a spring loaded self adjust mech on it.. take not on hows this works before taking off old cable
car up on jack and stands
drivers wheel off
un clip old cable from the clutch arm near the battery on the g.box to give pedel slack
arch liner out (moved aside)
undo cable from clutch pedal inside the car
reach through the arch liner and pull the cable out (stuck in with bung)
cable tie new cable to to end of the old cable through the arch liner then pull the old cable out bringin the new one in its place.
re fit new cable through the bulk head and clip on clutch pedal.
secure the gromet throught the bulkhead
clip cable in on clips on its root to the g.box
re clip on g.box
***job done***
Tried using this guide to replace the cable on my CUP.
How the F**CK are you surpose to get to the cable by taking the wheel lining out.
Took wheel off and removed liner as stated but the cable is the other side of the servo and you would need hands the size of a small child to get behind it let alone remove it.
This must be the guide for a 1.2 and not a Sport.
Had to get to it by pulling the heat shield away and putting my hand down between it.
The hardest bit was pulling the old cable out of the bulk head.
Had to cut it out in the end.
Job done now and it was well worth it.
The clutch feels so smooth.
