Clutch Cable Fitting
just wondering how easy these are to fit mine is doing alot of creaking so i think it may need to be changed . are they easy to do ???
^^ patients is a virtue Timbo ;) im sure someone will be able to help
Need mine done too .. just havn't got round to booking it in anywhere
quick guide
*** the clutch pedal has a spring loaded self adjust mech on it.. take not on hows this works before taking off old cable
car up on jack and stands
drivers wheel off
un clip old cable from the clutch arm near the battery on the g.box to give pedel slack
arch liner out (moved aside)
undo cable from clutch pedal inside the car
reach through the arch liner and pull the cable out (stuck in with bung)
cable tie new cable to to end of the old cable through the arch liner then pull the old cable out bringin the new one in its place.
re fit new cable through the bulk head and clip on clutch pedal.
secure the gromet throught the bulkhead
clip cable in on clips on its root to the g.box
re clip on g.box
***job done***
quick guide
drivers wheel off
re clip on g.box
***job done***
Tried using this guide to replace the cable on my CUP.
How the F**CK are you surpose to get to the cable by taking the wheel lining out.
Took wheel off and removed liner as stated but the cable is the other side of the servo and you would need hands the size of a small child to get behind it let alone remove it.
This must be the guide for a 1.2 and not a Sport.
Had to get to it by pulling the heat shield away and putting my hand down between it.
The hardest bit was pulling the old cable out of the bulk head.
Had to cut it out in the end.
Job done now and it was well worth it.
The clutch feels so smooth.
have you tried taking the battery and battery box out, I aint to clear on the location of the cables on them but my 1st instinct would be 2 strip it down from there!
Unclipping it from the clutch arm was easy to do (battery end).
It was getting to and removing the cable for the bulk head that was the problem.
There is no way you can replace it using this guild so anyone who reads this do do not waste your time trying.
Had one in the boot of my car for about 6 months .. never got round to fitting it .. needs to be done though
Fag
Fag
Are you saying the guide on here is correct then cos if you are your talking Shi*t.
Anway no thanks I gave up smoking new years day.
Guide worked fine for me, maybe you need to get inspector morse involved... ;)
Bullshit! Your not trying hard enough, I've done loads of these and hardly struggle. If your struggling to change the clutch cable luckily they've changed to hydraulic now for lazy b******s so your okay.
Don't follow this guide if are a girl/cry like a girl when your hands get cut up ;)
Bulls**t! Your not trying hard enough, I've done loads of these and hardly struggle. If your struggling to change the clutch cable luckily they've changed to hydraulic now for lazy b******s so your okay.
lmfao that should go for all pussys not wanting to get cut up doing anything on a car lol
Changed my cable at the weekend and gave the pedal a good grease.
What a difference,no more creaking and its noticeably lighter.
I must however say that I tried using the guide on here and found it impossible to get to the cable by taking the wheel lining off.
As said the servo is in the way.
I read the threads on here and kept persisting but no joy.
Is the 172CUP different??
