Steering angle sensor reset........
Car  Turbo Beige
How much do you think for this to be done by renault?
Its a fix for ESP and ABS lights on after steering wheel change.
I'm not sure what you need you've not gone damaged the angle sesnor have you if so it will be everywhere and there expensive to fit/replace.
I take it you mean you've tqken your wheel off and got ESP and ABS warning lights? If so need to fool the system to thinging the switches are still there the lights come on as the cruise is linked to the ABS system so no switch sets it off.
when you say the wheel has been changed has the airbag gone off?
the angle sensor is on the column where the indicators live
Yes steering wheel has been changed and i have ESP, ABS and serivce lights on. I was told that reseting the steering angle sensor would sort this?
if you disconnected the battery when you changed the steering wheel then it will need to be reset using renault clip proberly about £30-40 labour.
