I don't know about the cooling system on the Mk2's, but on Mk1 clios there is a sensor that goes in the side of the radiator and this controls when the fan comes on and off. I would imagine there will be something like this on yours and if you have tested that the fan works, and you know the radiator is heating up I can't see what else is could be tbh.
the fan used to come on all the time on my valver, i'd never really noticed until recently thinking about it, but in the few months i've owned the 172 the fan has never come on
will they charge me to diagnose the problem, or is it just gonna be plugging in a fault code reader?
As far as I am aware, there is only a fuse (which is in the e-box under the bonnet) a relay behind the passenger side fuse box, and a temp switch (which is in the rad) controlling the fan.
If you pull the plug off the temp switch and short the pins out the fan should run.
If it doesn't, suspect the fuse first then the relay.
Check the fan will turn as sometimes they can jam in the shroud.
thanks Brian i will try it, the recovery guy tried shorting the connection to the fan but it still wouldnt turn so he ran a lead from the positive battery terminal to one of the pins and it started to run, I replaced the resistor pack based on his advice but it hasnt worked, could one of the relays have prevented the fan from engaging (ie if its stuck closed)
do you know which relays to try?
also how do you test a relay or is it better to just replace??
As far as I remember Matt, there are three connections in the plug to the rad-stat. The fan, according to the manual, has two speeds, so you would have to short out the right two to get it working.
I will have a look at my Sons car when he gets home tomorrow if thats soon enough for you.
Whoa up Matt.......the thermo switch is nothing to do with the resister pack, thats a heater fan speed control device.
Its the temp sensor is on the water coolant radiator that switches the fan in front of the radiator, ON, when the engine temperature rises above a preset limit. Nothing to do with the cars heater.
Its not commonly called a thermo switch, its really a Temperature or cooling fan switch.
I had a quick look at a parts list and i noticed there is also mention of a resistor unit to control the 2 speeds of the fan. It would appear to be on the bulkhead behind the engine.
I would much prefer to check all this against my Sons car when he gets home later, rather than guess. If thats OK with you.
if so you may have created an airlock which will need to be got out. leave it running with the cap off the header tank and the water will eventually boil and release the air.
an air lock will stop the coolant flowing properly and it won't get to the temp sensor
ah, i havent changed the temp switch, might have to invest in one of them
Chris i have changed the coolant, but that was after it over heated the first time, and when i changed it, i did what you said about leaving the cap off to get rid of any air
but i can certainly try it again, as it wont cost me anything to test it
I cant see any sensors bolted into the side of the rad, all the air con pipework is running around it, and the area that Brian has indicated in his diagram is blanked off, I guess the coolant temp sensor is located somewhere else on models with air con?
I looked at my Sons car and there is definitely a temp sensor switch with 3 wires as shown on the diagram I posted. It is under the air filter box and very hard to see.
The resistor pack is on the bulkhead and equally inaccessible.
His car has air con so there shouldn't be any difference.
I am stuck now, not sure how i can help further. ....... Sorry.
I've taken some pics of the sensors nearest to the rad, maybe someone can tell me what they are, i've just replaced the sensor in pic No.3 last week and it didnt solve my problem.
what are the other two sensors? is No.2 something to do with the air con?
Thats the one, in picture 3 !! Pull it off and short the green wire to the blue wire then the mauve wire. The fan should run (ign on)
If not, as the switch has been changed, you need to look at the resistor.
just tried that, i could only get it to come on by running a wire from the positive terminal on the battery to the second connector, it wouldnt come on when touching the 1st connector on the socket.
