Driveshaft gaitor split!!!
Car  Clio T 314hp c43 AMG
Hi guys
My drivers side inner gaitor has split on my 172, just wondering.........
1, is it a easy job, does the shaft just pull out of the box?
2, can i just buy a gaitor kit or is it a complete shaft?
3, am i going to lose any oil from the box when i change it?
4, and has any one got a shaft for sale?
Thanks guys your feed back would be a great help
Scott :approve:
If its like my valver then for drivers side you don't have the drain the oil, you can buy boot kits which are pretty cheap circa £10 isn't difficult depending on the tools you have, you might have to take the shaft to a garage to get the boot on properly/clips tightened.
as above posts changing a 172 gaitor is virtually the same as a valver. driveshafts arent that cheap id rather spend £30 on a gaitor and spend a bit of time getting dirty
i paid £61 for full shaft and cv joint. if it drys up is horrible mate. mine was crunchin and wobbilin me steerin wheel.
GSF do drive shafts but I am not sure if they do one for the 172. When I had my 5GTT when the gaitors split I would buy a complete shaft. GSF do an exchange service as well.
The car I have now clio 172 on an 03 had a new drive shaft fitted with the previous owner.
I could tell Renault had done it, because they didn't even bother cleaning the inside of the wheel it was thick with grease. Lazy people. :rolleyes:
All this changing drive shafts business over a split gator, fook that, for less than a tenner for a boot kit and a bit of effort, job done.
common issue and as renault do under warranty is best to get a new shaft. think its around £150 for the part iirc.
Its only best if you dont mind spending an extra £140 or £100 for a garage to replace.
I cannot believe people are talkin about a whole new shaft just for a burst gaitor. the cost like a tenner and im no mechanic and i can fit them easy enough...:eek:
