The all singing all dancing 182 induction kit thread..
  182 Cup
Ok so, I see folk saying that some kits cause you to lose power, while some smoothe the power out and make you lose the 5k kick, I definitely dont want either so I guess I need to go for something that makes the engine sound even better but wont cause any of the above issues.
Any reccomendations please?
G_F
  BMW M3 & Williams 3
None make the engine sound better, but you want induction roar! piper my friend.
  VRS
ive had an itg panel, a viper and a maxogen
the panel is best value for money but makes very little differnce in the noise stakes, it does free up the revving a bit more over standard tho
my viper roared like a beast but created a lot of flat spots in the rev range, i didnt like this but apparently a good remap will sort that out and good bhp gains are possible :D
i now have a maxogen which imo is the best but it comes at a hefty price, i only have mine as i got it for a rediculously cheap price :)
its a bit quieter than a viper but imo the gains are slightly better, even more so with my rstuning remap :)
ive heard good things about the bmc and it is a good price :)
andy
  182 and 5 GTT
I had a viper which sounded cool, but as makavelli said there were alot of flat spots. Didnt notice any difference in performance though, although the standard box felt like the engine picked up quicker as the viper was always slightly hesitant as there was a brief pause untill it picked up. Im back to using a itg panel filter now though.
  VRS
yep exactly the same as my viper, u put the pedal to the floor............................... wait for it .............................. then off you roar lol
  Blue 182
I was thinking off trying to tweak my 182 but do you all think its best to leave as it is i just wanted it to sound diffr...............
len_beach
  E92 M3,172 track car
You can build your own Maxogen for less than £100. Buy yourself a phase 1 172 airbox, I picked mine up for £7 delivered, there's one on Fleabay at the moment, an ITG panel filter which is around £35, 2m of 70mm induction hose for around £20 and a 70mm silicine inlet elbow for around £20 again. That little lot comes to £82 but may be a little more for the airbox.
  VRS
yep good idea matey! the phase 1 airbox is basically a non carbon maxogen :D
  Blue 182
so when you do all this to the car what do you get out of the car is it just the sound or will it go better
R
rich[182]
Just do what I did in post 1 & 10 here except you don't need the blue hillpower bend, just get ITG panel filter and have cold air feed pointing directly above the opening to the acoustic valve, sounds awesome, doesnt suck in hot air and costs nowt, sounds same as my mates BMC
Picks up its cold air from same place the Maxogen does
I've since added 2 further feeds from the cold air pickup point down near the arch liner and fed them up to apertures arround the acoustic valve area behind the headlight
http://www.cliosport.net/forum/showthread.php?t=204775
len_beach
You may get a slight increase in sound and performance with a performance filter and some uprated feeds.
I am expecting bigger things from the phase 1 setup I mentioned earlier as the surface area of the phase 1 panel is 2.8x larger than that of a phase 2/182.
