Boot lock
Is it the right key ??
If not you have to go in from the back of the tail gate. Remove the rear panel and take out the lock. See if it will work with some wd40 if not get a new one.
Key fits all other locks on the car, tried the wd40, no joy as yet. I've had the lock out but could not get the barrel out of the lock assembly. Breakers wont sell me just a boot lock, gotta buy a whole lock set!
Try injecting some really thick grease or Vaseline into the lock then jiggle the key as you try to turn it.
Lubricating it with WD40 or thin oil will be good if it was working but the last thing you want is all the tumblers falling into place if the key isn't holding them.
When you do get it open, you can clean and re-lubricate it.
