rear boot badge??
Car  Clio
how do i remove the chrome badge from this section?
I can see three screws but the thread is facing me and i cant see whats holding the badge in place??
Cheers, Mike
you can't, end of. Sorry lol!
It's plastic glued all the way round and would probably break if you forced it apart. The 3 threads you can see are what fasten the boot lock to the tailgate.
mines different to this was just speaking to mikey on msn about it... i can seperate my badge from the other bit...
I couldn't separate mine on the 1.2 it was one unit, I masked off the area and sprayed the diamond to suit.
Looks like the tabs are melted on, you could always cut through them and glue it on afterwards :)
The badge is stuck on with double sided foam sticky tape , just pull it off .
a bit of masking tape needed then huh...... lol
at least its one part of the car securely attached
aye mate just done it, put plenty on and got close to the edges, its come out alright thank god :D, any suggestions what to use to remove the glue from the masking tape??
cheers
