I really would check the switch first.
Someone else had the same problem a few weeks ago and swapped the switch with one off his mates car, and it worked again.
So all he had to buy was switch.
A lot cheaper than the control box.
The passenger side works in-directly on a relay via the UCH , the drivers side has a module in the door that gives you the single touch open facility on the drivers side only.
The switches are also different for drivers and pax side.
I was putting mine up a few months ago and heard a bang - and had to buy a completely new unit, in the meantime though I took the door apart and propped it up with a bit of wood
