I don't get why people bother with cold airfeeds to a normal cone IK like that?
Why not just route the IK to the front grille?
Sam
pretty sure you will loose power with 1 of those massive relocation pipes, and with the air feed it directs the air straight in the adaptor plate so just as good, ive also taken that cover behind the grill out so more cool air. I would rather have mine then a hillpower 1 or the ktec 1 with the massive relocation pipe
How would you lose power with the relocation pipe :S?
It doesn't matter where the filter part is does it?
I doubt the cold air feeds are making much, if any difference to the temp of the air flowing into the cone. Check out the angle on the grey tubing and then the other tubing is coming from near the fuse box (I assume?) so no air will be forced in anyway?
Sam
K&N Panel filter in original airbox with 75mm CAF is the way forward :rasp: I decided when I was sluggish as soon as the hot weather came i'd revert back to standard with uprated panel filter and I'm glad I did!! :approve:
Don't get me wrong, I do not doubt the physics of it all; colder air, bigger bang...
But what I do doubt it the effectiveness of the photo'd air feeds. As I said the one coming from behind the off side headlight will be doing sweet FA and the grey one is bent to such an extent I doubt there is even any air flowing out the end!
I am unclear as to exactly what you were saying about the relocating of the filter (I am not being funny btw) but the amount of airflow that gets to even a small engine like a 1.2 is staggering and the heat of the rubber like material that a Hill Power or CAF piping will make to the intake temp will be negligible.
The only disadvantage to relocating to the front grille will be the loss of induction noise.
Sam
Sam
I am not saying get a proper relocation pipe - IMO they are just for aesthetics. Just get a CAF pipe and then attach one end to the adaptor on the airbox and the other end onto the IK.
I really am not convinced about that silver pipe due to the angle.
Why would it be going around in circles?
Cut the pipe to size, so it goes straight from the cone filter (located behind the grille) to the adapter plate.
I'm looking into this as i just got my pipercross through the post yesterday and it seems to be sucking a hell of a lot of hot air. I'm planning on putting 2 feeds on mine from the inner spotlights and make some scoops to increase the driving force to the air.
i would get a closed system. like a BMC CDA or viper. by the time you have open IK + sudgested SAMCO hosing and *****ed around relocating it. IMO the cost are prob the same
Any chance of a pic of your setup mate? Not that I intend copying it on my 1.6 at all.![]()
Yea Im sure!! :rasp:
Haha, yea I will try and get some pic's tonight when I get home.![]()
As Sam suggested I was going to re-route my filter to directly behind the grill, but im not sure the effect rain would have on this?
Im bored with the IK now anyway, its abit annoying when your slowly edging past someone on a DC and the IK is going baaaaaaaaaaammmmm and your hardly moving!
