How it should of left the factory
I sense a trend ;) Looks good though Steve, I've just completed mine, done gear insert and steering badge too :)
erm the stearing wheel insert needs doing and so does the gear knob insert they look a bit out of place otherwise although a vast improvement on stock. Good Work.
Yeah sure, I'll start my own thread so as not to hijack ;) Look in Clio media in a few minutes :)
These are repalacement items with a new sticker.
Middo supplied the lot.
Just fancied a bit of colour ;)
not that i am biased or anything but does look better. If you wanna send me a gear knob insert/ wheel insert feel free will do em for next to nothing as i've got the paint in.
Middo,
Im from ClioTrophy.Co.uk and have seen this thread is this something you can do for anybody, should i be able to pick up some spare inserts?
Looks really good and agree thats how it should have left the showroom. :)
Marc
^ yep can do it for anyone just need to send me the bits, can normally get them done within the week.
Cant wait - sending mine off to Middo on Tuesdat, engine cover, door badges, all inserts.....Roll on tuesday!
Thats cool Middo, how Much for the two dash inserts and the steering wheel insert?
Need to source some spare ones first unless i just send you the original ones.
Marc
Middo can i get these from renault as items?? part numbers???
How do i get the others out, without damaging???
I think if i can get some i will send them over to you.
Cheers, top job.
Middo said:
passenger side - open the glove box and feel the lip underneath the dash insert and basically just pull them. they'll just come off.
drivers side - is slightly tricker as it proportionally has more clips. but try to lever it out from the bare edge (by where the key goes). again this just pulls off.
steering wheel chip - just pulls off, but is underneath the tip of the airbag. so you need to pull it upwards and then down so it clears the airbag. once you start it'll make sense.
gearknob - i tend to use a blunt knife to slide down the straight edge of the insert and use it to fork it out. however, be careful on this one so you dont damage the gear knob as they're expensive. it isnt glued or anything, so it'll just come out.
^^^ cheers.
Get a piece of string for dash inserts, slip it under, slide along & pull ;)
i done mine a couple of weeks back aswell, although I done the steering wheel and gearknob bits too, and put some stickers on aswell....renault sport and trophy ones. Very happy with the results tbh.
I quite like the way the steering badge and gear knob insert are silver - go with the pedals IMO.
Like it alot, a vast improvement for sure!
are you trying to make your car look like a fiat coupe? lol
