Two Bucket Method????
Car  133/225/CLS AMG
I'm probably being really dense here but what does the 'two bucket method' of washing the car consist of other than two buckets??? lol
I pride myself on the fact that my Meg never gets too dirty anyway so usually a quick rinse, followed by lambs wool washmit with car shampoo, then rinse again, then dry!
Never had any bother with this method and no swirl marks etc.
If anyone can enlighten me to this 'two bucket method' then feel free!! lol
PS - This could be the stooopidest question for some time!! lol
1) Soak washmit in bucket one and apply to car body
2) Put washmit into bucket two and give it a rub to remove grit
3) Soak washmit in bucket one and apply to car body
4) Put washmit into bucket two and give it a rub to remove grit
5) Soak washmit in bucket one and apply to car body
6) Put washmit into bucket two and give it a rub to remove grit
7) Soak washmit in bucket one and apply to car body
8) Put washmit into bucket two and give it a rub to remove grit
9) Soak washmit in bucket one and apply to car body
10) Put washmit into bucket two and give it a rub to remove grit
11) Soak washmit in bucket one and apply to car body
12) Put washmit into bucket two and give it a rub to remove grit
13) Soak washmit in bucket one and apply to car body
14) Put washmit into bucket two and give it a rub to remove grit
15) Soak washmit in bucket one and apply to car body
16) Put washmit into bucket two and give it a rub to remove grit
17) Soak washmit in bucket one and apply to car body
18) Put washmit into bucket two and give it a rub to remove grit
19) Soak washmit in bucket one and apply to car body
20) Put washmit into bucket two and give it a rub to remove grit
21) Soak washmit in bucket one and apply to car body
22) Put washmit into bucket two and give it a rub to remove grit
23) Soak washmit in bucket one and apply to car body
24) Put washmit into bucket two and give it a rub to remove grit
25) Soak washmit in bucket one and apply to car body
26) Put washmit into bucket two and give it a rub to remove grit
27) Soak washmit in bucket one and apply to car body
28) Put washmit into bucket two and give it a rub to remove grit
etc etc etc until the car is clean
Lol, basically...
It rinses off grit and dirt that will be on the washmitt after you've passed it over the car into a different supply of water, so you're not just recycling the dirt back onto the car again.
As above one bucket with your wash, one with clean rinse water. After washing a panel, rinse the mitt in the rinse water before going back into the car wash one.
Aaah I see!! Its all become clear.
I have to say, I'll definitely give this one a try if the Meg gets really mucky. I've found that a quick rinse first just to get the dust off the car and then washing over it normally has kept it mint though.
Cheers for the infor guys!!
Well when you consider that my Meg has only done 2800 miles since Jan last year, it doesn't actually get that dirty.
No swirls here -
Well you have to take into account that the car has done such little mileage, gets covered when not in use and now lives in the garage when not used!! lol
Even though I haven't used the 'two bucket' method, the bodywork never gets enough crap on it to cause swirls or scratches when washed.
