everything else apart from the RS clios require spring compressors
42min is the current record
fred is right, the compressors arent required for taking the springs off...
putting the new springs back on however is a pain in the arse, as they need to be compressed to get the top nut back on. Thats why i mentioned it in my guide.
Also, if i didnt mention them in my guide and someone damaged something, i would get the blame. Just like someone tried to blame me for their fuses blowing after them following my rear light cluster guide :dead:
yes 42min all round on the floor using 1 trolley jack and 1 axle stand, although i reckon i can do a sub 40, must have a go one day
you need to pull the shock all the way up, then quickly whack the top mount on, push down, and enough thread will poke out so you can spin the retaining nut on a few threads, tighten up the retaining nut, and it'll compress itself
called mole grips :lolup:trade secret
never damaged one yet, takes hardly no force at all to stop it going downno! they would damage the piston!
nope, 1 man job, no extra parts or aids needed
