Ph2 172 Upper inlet plenum...will it fit a 182?
Christopher
Car  Z4M
As above. Or do i need an inlet from a 182?
i know the fbw throttle is the same but i'm sure some of the power gains over the 172 are in the inlet? :S the casting is improved possibly? better flow?
Chris
The 'Renault sport' bit? If so no. Has different breather arrangement iirc
The lower inlet manfifold is generic but as Gaz said, the plenum (Renaultsport bit) is specific to each model.
Sounds like a much better design. Is that the breather that comes through from the rocker cover?
Bugger. That breather makes a right old mess. If i'd have known the difference I would have made the change as I'm having my belts changed in a couple of weeks so I could have done the rocker as well.
In the words of James May 'Oh c**k'
